recover contacts n96
1 replies · 4,686 views · Started 22 November 2008
Hi all,
i have N96, i had to format it (reset factory) but unfortunatly i didn't had a back up of my contacts.
is there any way to recover my contcats which was on phone memory
note: i tansferred them from my old obile by sending them as business card using bluetooth to my N96
perthachy wrote:Hi all,
A regular reset factory settings wouldn't erase your contacts.
But if you did a deep reset with reformatting everything then they are no longer on the phone.
You can use PC Suite to back them up / synchronize to a PC.
Or Ovi Sync to sychronize over the air with www.ovi.com and re-sync from there.
If the only place you have your contacts is now the old mobile, why don't you get that one synchronized with the PC, and then sync from the PC back to your new mobile?
