Hi guys, ive finally got a new N96 😊
Just a few questions:
1. Is there a way of debranding without voiding my warranty? I did this to my N95 which broke and i couldnt get it repaired under warrenty due to debranding
2. If i use a euro firmware will it enable DVB-H? It'll come in handy when travelling europe i can imagine
if u change product code and update via nsu nokia log ur imei and the prod code, the only way to do it without causing probs is to use phoenix on ur pc. U can then flash it with euro1 without changing product code.
thats interesting... i didnt know nokia did that.. crafty
so if i dont use NSU for changing product codes i should be ok in terms of warranty?
also with phoenix does it require any hardware or a special cable?
no u just need latest phoenix, the n96 fw and a gud pc and the usb cable u get with n96.
sweet 😊 i'll have to do some searching
cheers
