i8510 Gallery Button Folder organisation
1 replies · 4,634 views · Started 25 November 2008
Hi
when you click the 3 position slider to gallery and then press the camera, you get the alternative gallery.
i like to put all my pics into seprate folders.
this takes ages.
is there any way to edit the directory structure and folders used in the third button position gallery on the pc.
it takes too long to put a load of pics into separate folders, can this be done on the pc
many thanks
That doesn't look possible. The folder structure in the gallery app seems to be maintained in that application only. I was hoping that a tag would be put on the image file but this is not the case.
One thing that might speed up your organisation though is that you can hold down # while navigating over pictures. This will mark multiple and you can then move photos into folders in batches.
