How can I do a save as command on a browser for this phone.
what browser should I use for that .
Also ideally i want to just over wireless copy files onto my memory card.
Any freeware software for that ?
1. Go to mini.opera.com and download the version of Opera Mini with multiple certificates.
2. Go to App Manager on the phone (I don't know where it is on the E71 as I'm using an N95), scroll down to find Opera Mini, press left soft key and select "Open" from the menu.
3. Enable "Read User Data" and "Edit User Data" (and anything else you want) then exit cleanly out of App Manager.
4. Run Opera Mini and nav to the download site. Find the item you want and select it to download. When given the option ensure you tell Opera to Save the item not to Open it. If you select Open control will be passed to Web which will only download if it recognises the file type.
5. If you're done all this correctly Opera should give you a dialogue box that will let you save the item wherever you like on the phone or card.
I hope this helps.
