Navigation Software?
5 replies · 2,635 views · Started 27 November 2008
What do u guys use mostly?
Gmobile XT is working but after moving from my Real tomtom its not as nice.
Estimated time and warnings etc are nothing near what I like about tomtom.
Would like to try a few others. Any ideas . thanks
I use ALK's Co-Pilot Live V7 - I have also used TomTom (but on a Windows device) and the CPL easily matches up to my TT experience.
CoPilot takes ages to get a lock on my phone compared to Nokia Maps. Do you have this problem (> 1 min)
Now that you mention it, I do - yes.
I use Google Maps and that gets a lock very quickly, but just tested (and timed) my Co-Pilot and that came in at 66 seconds to get a fix.
Anyone else have this problem?
I couldn't get CoPilot to install properly on my E71 (it's not a supported device though).
I've opted for Route66 Mobile 8, which is on my list for Santa.
I've used R66 before, on WM, and although it was never my favourite it looks like being the best of a bad bunch for my purposes
The latest version of Co-Pilot - 7 - is listed as compatible with the E71. That is the version I use and it works perfectly - aside from the startup delay on GPS fix.
