For some reason the locking function to lock the memory cards has vanished from my 9210i, this is weird :roll: :roll: , can anyone help, i'm just puzzled! :-? :roll:
NO locking function on 9210i?
It depends on the MMC
My 64MB MMC doesn't support locking, but it works fine with the 8MB one :-?
I had the same problem with my 32 mb card, but I also had a panasonic digital camera wich uses the same cards, after formatting the card with the camera I was able to use the lock function again... weird because when I formatted it with the communicator this was not the case...
[quote="Special"]It depends on the MMC
My 64MB MMC doesn't support locking, but it works fine with the 8MB one :-?[/quote]
You can only lock Nokia MMC's no other one's are supported :cry: , but i'm just puzzled why there is no locking function on my 9210i anymore :roll:
[quote="4u2nv"][quote="Special"]It depends on the MMC
You can only lock Nokia MMC's no other one's are supported :cry: , but i'm just puzzled why there is no locking function on my 9210i anymore :roll:[/quote]
but i can lock my Siemens 32MB MMC :roll:
It rily depends on the brand of MMC u have! Obviously NOKIA MMC r capable of such function, but the cheaper ver in the market now r unfortunatley not capable! But who cares if u cant lock it! if its cheap!
But i do think that MMC's made by Apacer is also capable.
