Quake III on GT-i8510
1 replies · 3,244 views · Started 28 November 2008
Yes, we can! Hinkka can, anyway. Get it here:
http://koti.mbnet.fi/hinkka/index.html
Network play is said to work, including running a server......
Copy all *.pk3-files from your computer to e:\quake3\baseq3. You need to have run the latest patch. If you copy other files then .pk3 it won't work.
You need to set up the keys before you can play. Also, you'll need to lower the graphic settings to get an acceptable framerate. It has to do with the "fpu" not working, according to developer.
Screen rotation is broken in this release, so you're stuck playing in stretched portrait mode. Let's hope it gets fixed.
And please consider donating to the developer if you like this!!
