Delete standard profiles
2 replies · 2,302 views · Started 29 November 2008
Hi!
Is ist possible to delete the standard profiles (don't need any besides silent and standard) Using N85
Thx!
From within the Profiles list on the N85 handset itself I don't think you can delete any of the pre-installed profiles. You can, however, rename all but the General profile. Any user-created profiles can be deleted provided this didn't start out as a pre-installed one in which case it can't be deleted.
I don't know whether it's possible to go into the phone's registry or "private" folder and locate the profiles there and delete them that way.
F
