Go figure, 3.0 is compatible with FP2 phones except for N96, they are working to rectify the situation however as it stands, flagship gets a shaft....what do you say ?
Nokia Maps 3.0 beta not compatible with N96 yet !
Installed and working fine, still not a patch on TomTom tho!
Where did you get your info that it's not compatible?
On beta labs, they recommend not putting on the N96 as it has some 'issues', though they dont say what.
Maps 3.0Beta works with all Nokia devices based on S60 3rd Edition Feature Pack 2 except N96, where we have still known compatibility issues. S60 3rd Edition Feature Pack 1 support coming soon.
MapsBeta on Ovi works on IE6 (Windows XP), IE7, Firefox 2 and Firefox 3 (Windows XP or Vista). Give feedback
source: nokia betalabs site/compatability
so yes it may work with issues
radical24 wrote:Maps 3.0Beta works with all Nokia devices based on S60 3rd Edition Feature Pack 2 except N96, where we have still known compatibility issues. S60 3rd Edition Feature Pack 1 support coming soon.MapsBeta on Ovi works on IE6 (Windows XP), IE7, Firefox 2 and Firefox 3 (Windows XP or Vista). Give feedback
Interesting.
45 mile drive home for me - I'll use Maps and let the forum know if I spot anything.
radical24 wrote:Go figure, 3.0 is compatible with FP2 phones except for N96, they are working to rectify the situation however as it stands, flagship gets a shaft....what do you say ?
*cough* http://www.engadget.com/2008/12/02/nokia-unveils-flagship-n97-phone/ *cough*
Nokia's got a new Flagship as of today.
munkiii wrote:*cough* http://www.engadget.com/2008/12/02/nokia-unveils-flagship-n97-phone/ *cough*Nokia's got a new Flagship as of today.
technically yes, however because it has not been released and we might wait for another six months or so before it actually hits the streets, the N96 still remains a flagship at least on the 'street, hands on' level 😉
installed ok .. but failed to run .. kept crashing with a System Error! would be interested to know if anyone has got this working on N85.
Now I have no working Nokia Maps program on my N85 .. since I can't do a firmware flash to fix it.. 😞
yep works like a charm on mine so far, no issues, pretty fast load up and lock in position, will keep you posted but works great for now
radical24 wrote:yep works like a charm on mine so far, no issues, pretty fast load up and lock in position, will keep you posted but works great for now
I have had nothing but problems with it .. and I hate OVI with a passion ..
No N85 support .. it doesn't know my time-zone .. it wrecked a healthy installation of PC Suite.
FFS Nokia hurry up with a damn Firmware for the N85 so I can at least flash it back to square one. 😡
yeah ovi does not work for me, its a headache, but i downloaded the maps it was all good for a moment, no really big changes and then it crashed with a passion, i thought that situation was hopeless but with hard reset restored my baby back to life....will take a step back from maps for a moment
Like I said, i'd try driving with it for 45 miles last night. Failed miserably. Phone crashed, full reboot - and maps hasn't been stable or usable since.
Interestingly enough, it was working in the office before I started driving home. I had some great 3d pictures of the centre of Manchester (UK).
Re: Seki.
Just re-install nokia maps 2.0 - it appears to remove the beta.
Flip95 wrote:Like I said, i'd try driving with it for 45 miles last night. Failed miserably. Phone crashed, full reboot - and maps hasn't been stable or usable since.Interestingly enough, it was working in the office before I started driving home. I had some great 3d pictures of the centre of Manchester (UK).
Re: Seki.
Maps 2.0 is installed but I still have the Smart2Go label on the app and the generic # icon .. instead of the Maps label and the globe icon.
Are you suggesting I re-reinstall 2.0 ?? 😊
Sorry Seki, I was wrong.
The reinstall of v2.00 maps does not fix the problem.
I've tried reflashing my f/w - that didn't solve it either.
Anyone any bright ideas?
Flip95 wrote:Sorry Seki, I was wrong.The reinstall of v2.00 maps does not fix the problem.
So try it again .. maybe ?? 😊
Not nice, but if all else fails....hard reset?
didn't need to backup or restore a thing .. in this "crossgrade" Of course I took a backup as a matter of course but I didn't need it.
I did need to run the FW updater twice though...
first time gave me the phone back with 15mins left .. it was hung .. (I left it for 4 hours!) .. so I killed it .. restarted the process again. 😊
seki wrote:didn't need to backup or restore a thing .. in this "crossgrade" Of course I took a backup as a matter of course but I didn't need it.I did need to run the FW updater twice though...
Hi , I had the same problem installing maps 3.0 to N96 (RM247 11.101) The PC says it's okay but I fail to start the application it says "system error" while loading. It is really annoying, what shall I do now? I also reported the bud to Nokia via Ovi, I excited about the answer.
ricsko wrote:Hi , I had the same problem installing maps 3.0 to N96 (RM247 11.101) The PC says it's okay but I fail to start the application it says "system error" while loading. It is really annoying, what shall I do now? I also reported the bud to Nokia via Ovi, I excited about the answer.
Open File manager on the phone ..
delete the cities folder from the card
delete the qf file from the card
install http://nds1.nokia.com/files/support/global/phones/software/Nokia_Maps_2.0_4503_3.2_u.sis
grab any maps you need using the map loader
Don't touch Maps 3.0 again until its released for the N96 / N85 properly 😊
finally I received answer from ovi, please find below :
Hi Richard,
Thank you for emailing Nokia Careline.
I would recommend that you uninstall the Nokia Maps 3.0 Beta from your mobile phone. You may do this by following the steps below:
1) On your mobile phone, go to the "File Manager" application found in the "Tools" menu
2) In the "File Manager" application, delete the "cities" folder and the "qf" file on the memory card
After uninstalling Maps 3.0, you can reinstall Maps 2.0 on your mobile phone. You may do this by referring to the steps below:
1) Go to to download Nokia Maps 2.0 and Maploader
2) Reinstall Nokia Maps 2.0 on your mobile phone by using our PC Suite software
3) Once you have reinstalled Nokia Maps 2.0 on your phone, please startup the application
4) Use Map Loader 2 to redownload the maps data to your mobile phone
I hope that this information assists you. Have a good weekend ahead, Richard!
You may like to visit our website for more information and support on Ovi.
Kind regards,
Roy
Nokia Careline
