I already own two of Nokia's most spectacular mobile phones, the Nokia N95 and Nokia N95 8GB.
The current firmware version on the Nokia N95 is:
V 30.0.015
15-07-08
RM-159
Nokia N95 (01.01)
and the current firmware version on the Nokia N95 8GB is:
V 30.0.018
23-07-08
RM-320
Nokia N95 (01.01)
So my question is: What are the latest firmware versions for both the Nokia N95 and Nokia N95 8GB?
Those are the latest firmware versions...
v31 is d latest firmware out dude.....
mfssfm4life wrote:v31 is d latest firmware out dude.....
yeah, it is now... wasnt when he posted. 😉
Have just updated to V31.0.014 firmware...140MB!!!
Didn't spot any differences on the menus, folders, etc...
No menu animations.
Active standby has the same options
I noticed it a bit faster than it was previously...
How about you? What is it like at your end? any difference? why the 140MB download???
Is there a latest firmware for N95 8GB. The N95 8GB I currently have, has the following firmware version:
V 30.0.018
23-07-08
RM-320
Nokia N95 (01.01)
So my question is: What is the latest firmware version for Nokia N95 8GB?
you have the latest fw version for 95-8.
Do you have a problem you are trying to sort?
95-1 changelog isnt around at the moment, but its supposed to be mostly bug fixes in a possible last hurrah.
If you go here you can stick your product code in and find the latest fw version.
