More NSU updates
22 replies · 7,676 views · Started 04 December 2008
Nokia continue their ultra busy week. Following the N95 v31 update (below), there's now a new version of Nokia Software Update (1.4.7) and new v11 firmware for the N85. Whatever next before the day's out? Source: p@sco (again, in Italian!)
Thanks for the heads up! Excellent news.
Just updated my N85 firmware. And ALL settings are "untouched". Was it DEP or somehing. 😮
Hey !! What�s about the N95-4 ????
My N95 8GB NAM is stuck in V 20.2.005 and still no ASR (Auto Screen Rotation) or any solution for the suttering video problem reported on several places !!!! (among other minor bugs)
I updated my N85 to v11 with no problems. I still can't get Maps 3.0 working, though.
hi, pls any feedbacks for those who updated? Was it worth it? My complains are mostly hardware related so am not sure if i need to update ? btw are the pics any better ? Thanks!
Yeah. Some connection problems to internet. So Nokia CAN NOT preserve user settings. I am serious. N85 was Zombie when released due the firmware. Now, when I use NSU, all fucks up. They will never learn.
Actually I am fed up with Nokia phones (currently using N79, N80, N82, N85 and N95). Nothing has changed concerning FW update. You can never trust them.
They will deliver Vine, Email, Maps 3.0 Alpha etc totally IRRELEVANT crap. 😡
bertolt wrote:@hih,
pls. be serious. i am about to upgrade my n85. did it really screw up your phone?
Phone is ok. But I had to install ALL stuff again. And "hard format" phone memory.
I am used to it. FW update -> wipe all -> install all apps again. Thats Nokia's policy. 😮
wooah, they got updates to N95 and many other phones, but where is updates to N79?? Phone is currectly so buggy shit, I wonder and lot, why they released it? Is this still a beta version? Argh!
New features and applications:
- DVB-H accessory support (SU-33W)
- Nokia software checker application
- Support forNokia MU-44 16GB microSD memory card
Changes/improvements:
- Bad sound quality using BT headsets (CAP 97705)
- Cannot display the video under edit menu (CAP 99698)
- Keypad no response after make call with slide close (CAP 99169)
- Problems with finding contacts starting by �CH� (CAP 97026)
- Music player keep searching new songs when activated (CAP 97082)
- Message type changed to multimedia message (CAP 99880)
- Video recording quality improvement
- Imaging quality improvements, better colours saturation and flash
- Defaul setting change: Closing slide doesn�t disconnect call
- Short slide key illumination applied for Java application compatibility
- �Video call� is shown in Options when highlighting a contact in Space UI.
- Not detecting always wall charger -> Not charging
- 2G cannot connect to GPRS service in some cities in China
- Non stop Music Player �Library update�
- FMTX: The audio is routed to DUT speaker after receiving a message when FM
transmitter is transmitting audio.
- Predefined contacts does not support Chinese characters
- APN setting for Vodafone Mobile connect �Promt Password is set to Yes�
- Audio >> downlink quality
- Some of the S60 key presses are not registered by device
- Google Maps application not working with �Vodafone live!� access point
- Network level icon is not shown during VT call
- ITU is not responding when MO is done where slide is closed and opened when call
is established
- Long press of Media keys prev/next not working correctly for local videos
- DTMF tones sent from prepaid line to *600 (or *400) are not received by NW
- OFR_pop-up at boot about positioning
- Orange enterprises APN is used by default in the email Wizard
- Pod cast: messed up characters
- All key presses are not registered by device
- E-mail address limiting to max 30 characters
- SMS converting to MMS if more than 20 recipients
You still can't charge from computer without locking your mem card.
I found a workaround, but remember, this makes the cable no more useable for data-exchange, you have been warned...
Preferably you should only do this if you have an aditional cable to use for data
Cut the D- and D+ (green and white) and on the nokia or micro side join them, on the other side insulate them sepparatedly.
Source: en.wikipedia.org/wiki/Usb#Power
Done - you created a charging only cable!
It would be handy if you could buy a USB cable with a three-way switch built into the cable. So you could then select:
1- Charging only
2- Data connection no charging
3- Data and Charging
I think I might make a trip to Maplin and give it a go.
I'm not sure what your issue was, Hih, but I didn't lose any data whatsoever. It was the smoothest firmware update ever (as easy as an Iphone update, perhaps even easier). I used NSU. It updated automatically, and then proceeded to download the update.
Unregistered wrote:I'm not sure what your issue was, Hih, but I didn't lose any data whatsoever. It was the smoothest firmware update ever (as easy as an Iphone update, perhaps even easier). I used NSU. It updated automatically, and then proceeded to download the update.
In fact I've done 3 firmware flashes of my N85 in 2 days .. one to unlock the FM Tranny .. a cross-grade .. a reflash to fix Maps after a wee debacle with Maps 3.0 Beta and finally v11.0.047 .. ALL of which didn't need a backup ..
"no settings or user files were harmed in the making of this upgrade" 😊
Now as to upgrading the good ol N95-1 .. yep back to the familiar .. backup // update // restore .. scenario
.. I love FP2 !! gee wouln't it be nice if the N95 ran it? 😊
Hih, I had absolutely no problems with this firmware update on my N85, everything went smoothly and ALL my settings and apps where restored perfectly.
well done nokia.
Quote:
Hih
This is crap. Nokia has nothing to do with your internet connection. If you live in a place where the connection is crap then this is your fault, not Nokia's. It seems like you are a constant complainer. The very fact that you eventually upgraded your phone means that your ROM flashing state was retained. You do not know what you are talking about so you should shut up.
Sergey Zak wrote:Just updated my N95-1.
Autofocus in Camera now a disaster!
Anything closer than 50cm have a very slight chance to be focused in.
Haven't touched a setting yet.
UPDATE: After Restore and Restart, things back to normal.
I hoped for http://cubeover.blogspot.com/2008/10/christmas-wishes-from-n95-s60-firmware.html :wink:
just a query mr zak. if i upgrade the firmware and i found out that the previous version was way better(or something goes terribly wrong, like blackout) is there a way to revert to the old firmware? do the restore and restart you mentioned revert the firmware? i'm new to this upgrade so bear with me. appreciate any response from anybody.
People know they have to backup before firmware updates and still complain about it erasing their phones? Seriously?
