My N95-1 Doesn't vibrate any more
4 replies · 5,239 views · Started 05 December 2008
I dunno when it stopped vibrating - wasn't paying attention - but vibrate is turned on and nto vibrating.
So I'm missing calls when the phone is on silent. And I want it on silent.
Anyone know if vibrate is a warranty covered repair?
Ta,
D
davecozens wrote:I dunno when it stopped vibrating - wasn't paying attention - but vibrate is turned on and nto vibrating.
Ta,
D
just try pressing hard on where the vibrator is located and see if it works. had same problem on my nokia 8310 and 6630
Are you sure vibrate is activated in the silent profile? I'm sure that by default vibrate is not active in silent profile
hippyguyman wrote:Are you sure vibrate is activated in the silent profile? I'm sure that by default vibrate is not active in silent profile
Sorry, should have been more specific. I've got it set to on in the profile (all the profiles) and I've just gone to the new fw - which made no difference - but does mean it's had a full reset...
D
