New battery theory
4 replies · 2,791 views · Started 05 December 2008
As I mention in another thread I got a new battery from Samsung and it went for over 4 days and I recharged it at 2 bars. After disconnecting the phone in the morning by midday (6 hours) it had dropped to 3 bars, the ony difference was that I had played some music off the memory card.
So I removed the card and the phone lost no more bars in the next 24 hours.
Could it be some application running in the background which accesses the memory card? But only when you have used the card.
vudluxi wrote:As I mention in another thread I got a new battery from Samsung and it went for over 4 days and I recharged it at 2 bars. After disconnecting the phone in the morning by midday (6 hours) it had dropped to 3 bars, the ony difference was that I had played some music off the memory card.
i got garmin on my memory card, i took memo card out to test battery, after chargin battery i lost bout 2 bars in 2 days with minimal use, third day used the fone bit more and the bars went quite quick, dont think my battery is all that good with or without memo card, where shud i go to complain bout battery as i bought my mob from mobiles.co.uk
I contacted Samsung directly, you can email them but all they'll do is ask you to phone them. They'll ask for your serial number so write it down so your ready.
Took 10 days for the battery to arrive.
Loosing 2 bars in 2 days is pretty good actually.
But generally, no. There's no obvious processes which the memory card "open" once it's been accessed.
vudluxi wrote:I contacted Samsung directly, you can email them but all they'll do is ask you to phone them. They'll ask for your serial number so write it down so your ready.
I contacted them!!! They woun't send me battery because this phone is still beeing tested! After finished and putting new firmware out...Then they will start to send new batteries to those who has battery problems!!!
That is what they have told me! Wish you luck all!!!
