Converting mp3
4 replies · 5,076 views · Started 19 February 2003
Is there any way to convert mp3 files to other file types supported by P800 but are smaller in size?
[quote="P800"]Is there any way to convert mp3 files to other file types supported by P800 but are smaller in size?[/quote]
www.cooledit.com
You can keep it as MP3, just reduce the bitrate and (optionally depending on if you are not listening through headphones) make it Mono.
A lot of freeware stuff that does this. If you need codecs, then choose LAME which is a good freeware MP3 codec
