I can only set one voice tag on each contact.
On one contact, I have home phone, business phone and mobile phone.
I want to be able to set all of these three with voice tag.
How do I do that?
I am able to add voice tag on another contact but not more than one on one contact.
Darno
how many voice tag can I add on one contact?
HI!...
Just ONE voice tag per contact...
And you have dedicated memory for up to total of 25 contacts max.
cya!
Yeah, you can only have one voice tag per contact. It's something that most Nokia phones I've had, had. Anyone know any different?
The only way to get around it, is a clumsy way of splitting the contact into separate entries.
or you could try Neu voice, which allows multiple tags per entry and other voice control options
Paul
alright then, if that's from Nokia, then I can't do anything else...
thanks
