I have a nokia n80 (i know shame on me). The screen has gone and I need to get my contacts and messages off the phone.
Now i can do this by using the PC suite. The only problem is the phone is set to default to mass storage mode.
Can anyone tell me the exact key sequence to set the phone in pc suite mode?
thanks
I'm pretty desperate, so if anyone can help it would be well appreciated.
Whether it can be done also depends on if you have the menu structure in the original order (e.g., if you have moved icons around, it'll be a bit of a trial & error attempt).
I don't have an N80 so I can't walk through it, and I don't have any other S60 3.0 devices at hand, either.
