NEW FEATURES IN THIS RELEASE
Switch 4.0 – improved switch application to transfer user data from/to other devices
IMPROVEMENTS IN THIS RELEASE / GENERAL AREAS
Still image quality is improved, with fixes for color haziness and motion blur that appeared under certain conditions
Many fixes for conditions that can lead to application crashes or instabilities
Improved overall Bluetooth interoperability Improved overall Bluetooth interoperability
Now compatible with Nokia Email service (application available as separate download)
If user sets brightness to maximum value the display backlight now does turn back on after screensaver mode
The device autolock no longer locks the device while viewing or recording videos
SMS no longer gets auto-converted to an MMS message if there are more then 20 recipients
Music Player “Refresh Library” no longer hangs if General Settings Date separator is set to “:”
Now only one message alert tone is played per synchronization with Mail for Exchange, instead of one per message
Fix for issue with alarm snoozing when alarm was set and device was powered off
Theme no longer jumps back to default theme after using USB mass storage mode
CSHelp texts are now updated to resolves several identified issues
KNOWN ISSUES IN THIS RELEASE
During boot, we recommend to wait for battery bar to show up prior to using media keys to ensure they are responsive.
Ngage pre-selects wrong access point in certain operator networks, in these instances user needs to reconfigure Ngage access points manually from within Ngage settings menu
Thanks to Mr G of N95users for the heads up.
