ICONS on desktop- Change
3 replies · 7,579 views · Started 09 December 2008
Hi
I have some icons (Shortcuts) on the desktop which I dont use much. How to get rid of them and get in their place applications that I need?
Please help.
If you're referring to the active standby apps, then yes you can change them...
go to
settings - general - personalization - standby - active standby apps
you can assign your most frequently used apps
hth
Thanks medium rare!
settings - general - personalization - standby mode- active standby plug-ins
and choose from the list whichever I wanna be on the desktop.
