i'm trying to set Automatic retrieval for e-mail box in my E90 but i get this error
"unable to enable 'Automatic retrieval' settings.define access points in 'Connection settings' first."
but i have many access point, EDGE, GPRS and my home and work Wi-Fi
they all work OK! but why does it think i have no connections?
You need to define 1 access point only in your email settings, if you have it set to "always ask" you can't set it to get emails automatically as it need user intervention to know which access point to use.
If you want it to always work, then set your 3g access point, else you can use your home wlan if you will be at home.
Thank you, although i'm in Iran and all i have is a 1Mbps wifi and EDGE
no #G
but thanks for your help
it worked
