Help with Navi2go on N96
2 replies · 1,838 views · Started 09 December 2008
Hi. Hope someone can assist with this one.
Bought and downloaded the above software from www.3dvu.com and have installed it on my N96. However when I try to launch the app on the phone it does nothing - you get the brief egg timer thing for about 5 secs then nothing..... I've removed and reinstalled but no luck.
The website shows the software as compatible with the N96 so am a little stumped. Have also tried emailing their support dept for a couple of days but just get an auto-reply saying their mailbox is full.
Hope someone can help who may have the program?
Cheers
dantyler wrote:Hi. Hope someone can assist with this one.
Cheers
have you installed it on the mass memory (16GB) or on a micro memory cad?
i have copilot live 7 on my N96 and it says it works on memory card but it does not, it would only work when installed on the phones mass memory..
good luck
Yes I thought of that too.... however when you install the app it doesnt ask you where you want to save it. I've just removed it again, rebooted and reinstalled to check I wasnt missing it, but no it definately doesnt ask
