Phone To Pc
1 replies · 1,238 views · Started 09 December 2008
What is the best software to handle your N96, I have pc suite, nseries suite, ovi suite nokia music, blah blah blah and the bad thing is non of them work right. Which should I use and which should I get rid off.
My friend has an iphone and it is unbelievably simple to do everything thru itunes.
Nokia please come up with some thing that works.
Also how does the location picture tagging work, do I have to wait an hour till the satellite pics up the signal then take the picture
If you want to send SMS more , you can use normal pc suite. To Message, Contact, Calender and Sync you can use Nokia PC Suite and for rest you can use Nokia OVI Suite and in future there wont be any NSeries PC suite, so you can uninstall if you want 😊
