since cleaning out my N95 8Gb earpiece with a toothbrush (external dust acummulated) my calls are all distorted, i�ve tried turning down the volume but then its too quieter but still distorted, not sure what i should do... any suggestions?
distorted ear piece
Simplest fix in the world my friend, courtesy of n95users.com
"Put the earpiece to your mouth, and blow and then suck really hard in it. That's it. You'll know when you've done it right because the distortion will be gone."
Original thread here if you're interested:
http://www.n95users.com/forum/its-broke/2019-earpiece-speaker-distorted-read-here-fix.html
It's true. I used to do the same with my old headphones when they'd start distorting. Worked every time.
thanks guys. it works:icon14::icon14:😊😊amazing, last year i got my new N95 8gb and immediately the earpice wasn�t working, as i only had the phone a day they replaced it, maybe this is a common fault..
