Dear fellows,
i have downloaded youtube application and installed it on my nokia n95. it runs very well, i can search my videos, or any video. icons of the videos appear perfectly but whenever i try to play those videos through WiFi, after a while of loading an error "connection to the server timeout".
I set up the Realplayer streaming settings and fed my WiFi access point. I did not change any other setting, proxy,port etc.
Does anybody know whta to do so that Youtube videos can be played?
Thanks for help
Youtube videos can't play on Nokia N95
Just to put you at ease, I was having exactly the same problem late last night. It was really annoying!
Anyway I've tried it now and it's working again. I guess YouTube had a temporary fault that they've now resolved.
Hi there,
This is my 1st post.
I have finaly got You tube to run stable on my N70. I just installed the Opera mini browser on my nokia N70 v2 and You tube is working great now, even via links.
Just follow the instructions:
1) Install / download Mini opera from Opera mini.com 4.02 website, directly to your handset
2) Make Opera mini your default browser
3) Set / point multimedia key to Opera mini for quick access on handset
4) Check Real Player access point and set to default web / gprs
5) Set network to GSM/ 3G
Hope this helps all N70 users
