Ringtones
9 replies · 4,198 views · Started 10 August 2001
I tried to import a midi into the new ringtone editor. the notes were ok but it didn't sound like the midi file. did i something wrong or is it a bug? does anybody know?
You might want to contact the author. He is friendly and would welcome a bug report (if it is one) - it might just be that the sounds for a ring tone are less extensive.
Rafe
wow! quick reply
The only limitation of the trial version is that it only converts the first
16 notes of the midi file
If you can send us the midi file we can investigate. Note however that midi
files should ideally be one track and one channel, since the nokia can only
play one note at once. There are various websites with midi files suitable
for use as ring tones for nokia phones
Keep an eye this afternoon (or maybe tomorrow) for a rather large collection of ringtones and wav files be uploaded to the site..
No not 10's, not even 100's but almost 1,000!
Given that most of the ring tones have no description, it would save us a lot of time if you can provide a link to a single zip file that contains all of the tones!
Thank you for this wonderful site.
I'm working on it.. The site is a part time hobby for me and I've been a bit busy recently. Hopefully I will be able to sort something like this out shortly (need to find space if zip > 1MB). Basically its on the list and suggestion noted.
mean while there'll be another 100 .rng files with descriptions very shortly. I've also received some arabic / hinid .rng files which I will also add soon.
