Need tips or software for this. (Super Simple PictureEditor)
1 replies · 1,840 views · Started 20 February 2003
Hello,
I use my mobile to automatically update my webpage using E-mail.
This works perfectly, however it would be very usefull for me to be able to rotate a picture after I've taken it. Let's say I take a picture in landscape mode, I can't use it for my website without rotating it on the P800 and attaching it. Is this possible today with exsisting software?
If not I would really appriciate if someone took the time to develop a simple picture editor. (That would enable us to rotate pictures.)
PS: I believe this problem still exsist for all the MMS people out there too!
Yours truely,
http://terje.sorgjerd.no
Send it as an MMS (if supported by your network), then when you insert the picture you can edit it, rotate, crop etc...
