Hello, I have a N95-3 with firmware v20.2.011 and N-Gage v1.10. My problem is that I cannot use the multimedia keys with N-Gage games. I have tried it with FIFA 09 and Metal Gear. In the last one I can see the "flip" option, however, it appears in gray, so in other words I cannot use it (the display direction in landscape has the multimedia keys to the left, should be inverted). Does anybody know how to fix this problem? Thanks in advance for your time.
Marko
You may need a new firmware version or N-Gage version or possibly both. Probably nothing you can do to fix the issue.
N/A wrote:You may need a new firmware version or N-Gage version or possibly both. Probably nothing you can do to fix the issue.
As far as I know I currently have the last versions available for my N95-3 (RM-160) of both firmware and N-Gage.
You could very well have the latest versions now, but as that apparently is not enough (you still have this issue), you need wait for even newer versions of one or the other (or both).
