Hi ..
Can any body have an idea on this...
while designing a form in view/edit mode or edit mode it will pop up the options menu with the following commands
add field
save
edit label
delete field.
Is it possible to disable the commands like Add field, Edit Label and Delete Field. For clear understanding please be refer to the form example given with the nokia series 60 SDK.
It will be greatfull if any body send an appropriate code / suggestions on this.
Haricharan
