HD Converter is a powerful video converter that lets you convert HD video including m2t, mts, m2ts, ts, tp, trp, mod, tod, HD video to popular video formats which can be supported by Windows, Mac, and kinds of Media Players. Besides, HD Converter can also convert the HD video to the foramts directly supported by iPod, iPhone, Apple TV, PSP, PS3, Xbox, Mobile Phone. What' more, this HD Converter can extract audio from the video easily.
It is remarkable that the HD video conversion is no lossy quality.
The following step-by-step guide shows how to use this HD converter?
Step 1: You have to download and install HD converter to prepare for the lossless conversion.
Step 2: Add the HD files- click
button, batch AVCHD video conversion is supported.
These videos you loaded will listed in the software and with the screen in the left pane you can preview them one by one.
Step 3: Edit the HD videos- you can Trim, Crop, adjust Effect, snapshot a picure and merge the add videos into one file.
Step 4: Set output option:
A: under the "Profile" downlist, choose the wanted format.
B: under the "Destination" option, select the folder to save the output in.
Step 5: Click
button to start conversion. A conversion window will appear to make you learn about the conversion progress.
OK, after a few minutes, you can enjoy the lossless video freely. What are you waiting for? Hurry up to try HD converter by yourself.
