9210 SIS Files
19 replies · 4,479 views · Started 20 February 2003
When you format you'll need to install all your applications again, some applications the 'core' apps are bundled by Nokia in 1 big installer. but to prevent unwanted apps from installing you could try installing these applications on there own. Shadow offers his services to create an isntaller to install those applications which are normally packed together seperately
so, boys, if you don` mail me, with specs about wich one you want, i will wait...please remember that all files are bigger than 8 Mb, so please be
gentile with your request. 😊
[email protected]
[quote="shadow1"]You can do that. 😮)
I have enough with FTP experience...[/quote]
For shure I do not. I am not that special.... 😃
Is anyone aware of a fix to get around the PC Suite problem associated with having more than one Symbian device.
I have a 7650 and a 9210 - I can synchronize both sets of data with Outlook etc, but cannot install software on my 9210 (I most recently set up the 7650 PC Suite). When I go to install sw on the 9210 I get a message saying it is not connected, even tho it is. If I link in my 7650 using BT at the same time, then the 9210 Sw tries to install on the 7650.
So there is a bug in PC Suite, at least wrt to supporting two devices that are capable of running Symbian.
[quote="erhum"]Is anyone aware of a fix to get around the PC Suite problem associated with having more than one Symbian device.
So there is a bug in PC Suite, at least wrt to supporting two devices that are capable of running Symbian.[/quote]
what i experienced is when i want to install .sis for 7650 it says file not supported or something like that
and what i did i i deleted the pc suite for 9210i and install it on my other laptop 😃 😞 😃
I had the same problem before but somehow it got fixed and I can operate both devices from my computer, after a while it stops recognizing the 7650, since I bought a MMC Reader I opted to uninstall the 9210 PC Suite and reinstall the 7650 PC Suite... solved my problem right then and there. 😉
So there is a bug in PC Suite, at least wrt to supporting two devices that are capable of running Symbian.[/quote] 😊
