Sending & Storing Text-files from 9500 to E90
1 replies · 7,574 views · Started 17 December 2008
😊The E90 cannot read my text-files , sent by bluetooth or irDA from the 9500 to E90 . The 9500 converses the text to .doc and the E90 recieves the message , but E90 cannot open the file nor the file can be stored in memory (C or E) so Quickoffice should be able to read it .
So all my text-files are still on the MMC in the 9500 . Any help ? BTW my ONLY PC's are the E90 + 9500 . Many Regards : jApi NL
😊 After all I found a work-around :
a. Send the file by bluetooth . The S80 (9500) converses the file which cannot be read by S60 (E90)
b. Use free third party application called "Activefile" to copy the file from Inbox to a folder in C : or E : .
c. Build in application "Notes" or "Quickoffice" cannot read the file yet . So you need another free thirdparty application called "Lightnotepad" . This application can read the File . However only up to 200kB it is able to edit . So to copy and paste the file to "Quickoffice" , you have to divide bigger Files in your S80 to smaller ones first . Later in "Quickoffice" you can join the divided files .
d. My 9500 makes a mess of the text files during transfer , so there is a lot of re-edit in "Lightnotepad" to do : actually deleting unwished letters and symbols . But after re-editing the text is fine and can be stored in "Quickoffice" by Copie and Paste : Ctr C or X -> Ctr V
😊 Regards jApi NL
