its about every softwary.. but i specificaly care about the orange gps.
i have installed the 30 firmware like 3 times today.. and just cant install any software on my 8gb sdhc or on my phone memory...
help plz...
help plz...
Could you give us a bit more detail please. Not sure I understand your problem.
[email protected] wrote:Could you give us a bit more detail please. Not sure I understand your problem.
yes dude and tnx for your comment-
when i install sis of jar files (comp to phone or directly from the phone) any application it is- i get the "unable to install" at the end of the waiting bar...
barricades wrote:Hi there, are you sure there is enough free space on your phone for the software to be able to fit + all it's temp files it might create for the install?I don't know about phones but if it was a 'puter that's what I'd suggest
5gb is free... :/
Niv-o wrote:its about every softwary.. but i specificaly care about the orange gps.i have installed the 30 firmware like 3 times today.. and just cant install any software on my 8gb sdhc or on my phone memory...
Check the following settings:-
Menu -> Applications -> App Mgr -> Options -> Settings -> Software Installation -> All
Menu -> Applications -> App Mgr -> Options -> Settings -> Online certificate check -> Off
dez_borders wrote:Check the following settings:-Menu -> Applications -> App Mgr -> Options -> Settings -> Software Installation -> All
checked... doesnt work :/
