encrypt/encode calls?
3 replies · 2,586 views · Started 20 December 2008
Hi, I am looking for a software that can encode/encrypt calls and/or sms messages so that they can not be sniffed, and would run on nokia 3230 (s60). Is there such a thing? Thank you
Note that with such software also the person you're calling or sending messages to would have to have the same software. Having such an app only on your phone won't make much of a difference.
Also, GSM calls are already encrypted, but it isn't that strong encryption, and in the USA it is even less so.
N/A wrote:Note that with such software also the person you're calling or sending messages to would have to have the same software. Having such an app only on your phone won't make much of a difference.
Yes i am aware that person would need the same software and probably a key for the encryption. Can you refer a name to such kind of software?
Yes, encrypting calls would be great.
I don't know any software that does that but I do know there is software that lets you add another factor of authentication for logins.
In laymans terms, if you try to log onto something that is protected by yoursoftware you get a call to your phone checking to see if it's really you.
