Synch with Outlook
1 replies · 1,341 views · Started 21 February 2003
With the t28 and T68 you could use the snych programs and set a filter to transfer only the phone numbers you wanted to your phone. This feature seems to have been left out of the P800 which means you have to transfer every phone number in Outlook to the p800.
Does anyone know a way to transfer only the numbers you want to?
I know this is anying, particuarly on such an advanced bit of kit. I have got around this setting up a seperate contacts folder to sync, then i copied the numbers i wanted into this. I know this slightly efeats the object but how often do you modify tour mobile contacts anyway. TRhis seems to be working very well and has caused me no inconvenince. 8)
