I have downloaded system.sis from warlocks site, how to change the system icons now?
thanks!
this is the file link:
http://robin.genx.be/nokia/modules.php?op=modload&name=Downloads&file=index&req=getit&lid=64
thanks!
...sorry!
this is the page of description:
http://robin.genx.be/nokia/modules.php?op=modload&name=Downloads&file=index&req=viewsdownload&sid=1&min=10&orderby=titleA&show=10
😮ops:
Well after installing they should be ... well installed 😃
Try deleting a file .. the new trashbin should be displayed instead of the old.
If not, mail n9k 😊 Cause I had nothing to do with this one 😉))) 😃
Good luck!
well it does that... also some .ini files changed their icons.
is there any way we can change them using the icons we got for iconmanager? 😃
It's something totaly different, but I'll keep it in mind for a IconManager v2 😉
wow, that'd be something to look forward to, iconmanager is great!!! 😃
thanks!!!
I have installed the system.sys file but no change are visible. How change the folder icon same the image of example? Please, if possible, write the procedure step by step
Thanks very very much
Hi! black biker, the purpose of this skin is change the original folder, dustbin, and the white paper from the file manager, as shown.
and this is another sets of difference view. I will create the original skin later in order to uninstall the previous systemskin. I hope you will like it as much as I do. 😉
WOW that babe is hot in the side view of one of your screen displays, how did you get her in there? WOW WOWOOO :roll: :roll:
thank you n9k
my desire is change the system icon like xp or windows style 😉
folder, disk, etc. is possible? 😃
black biker, I will try to fix it later. thanks for the XP idea 😉
as for 4u2nv, 😃 😃 😃 ... will upload later.
