Youtube not working
4 replies · 8,660 views · Started 25 December 2008
I need help, I just bought a Samsung i8510 Innov8, the browser and everything works just fine however when I try to open a youtube video the real player starts but the video does not load. It says loading 0% and just stops eventually.
It would really suck if I cant watch youtube on the phone.
Please help
Thanks,
Have you set the correct access-point in Realplayer? - i had the same problem and it was down to Realplayer trying to stream from a unused connection 😊
Thanks for the answer. I tried using my neighbors internet and it worked. So I think the reason for this is that my own wireless has a password, however real player never prompts me for one, which is why its never able to connect. Do you know how I would be able to type a WEP key or something for my real player?
Sorry about the last post, I think the problem is with my WiFi or some settings in real player, since my web browser works and it never asks me for a WEP key.
zukhraf wrote:Sorry about the last post, I think the problem is with my WiFi or some settings in real player, since my web browser works and it never asks me for a WEP key.
It is settings in realplayer... unlike the N96, realplayer has its own connection settings rather than using the same as the web-browser.. if you start realplayer thru the media menu. then choose options then settings then streaming then network you can change your default access point to what you want.
