E90 Switches off
2 replies · 3,962 views · Started 26 December 2008
Hi, I have been using my E90 for 1 year now and have been quite happy with th eperformance. From last 1 week i am having a problem that the mobile switched off automatically. THis happens while talking or even when phone is not in use. I have also tried updating the software to th elatest one but the problem still remains. i am not sure how this has started suddenly.
please let me know if there is any solution to this problem..cheers
😊 Hi , did you check battery-power ? Or did you try one of the firmware resets ?
Make a backup on your memorycard first : Instruments - Memorycard - Options - Backup .
Soft Reset *#7780#
Hard Reset *#7370#
Be Aware : even after making a backup , the Hard Reset will DELETE all your Calendar entries !! However it will save all the other data .
Go back to : Instruments - Memorycard - Options - Restore from Memorycard . Good luck !
😊 Regards jApi NL
amitchopra wrote:Hi, I have been using my E90 for 1 year now and have been quite happy with th eperformance. From last 1 week i am having a problem that the mobile switched off automatically. THis happens while talking or even when phone is not in use. I have also tried updating the software to th elatest one but the problem still remains. i am not sure how this has started suddenly.
How many programs are you using in background?
This can happend when you have a lot of programs running.
Have you tried to clean the memory using a task manager?
Regards,
