nokia 5800-product code for hebrew language
7 replies · 16,534 views · Started 26 December 2008
hi All.
is any body have idea if hebrew language can be supported by the 5800?:con?
i bought my Nokia 5800 in UK and hebrew language is not included.
would like to have product code to make my 5800 "speak Hebrew".🙄
thanks in advance.😉
Hey wabcdw,
I found a post saying the codes are:
0559407: Israel BLUE
0559300: Israel RED
Do you have any idea how to change the product code ?
I read nss still doesnt support 5800 and gives an error message.
roid wrote:Hey wabcdw,
0559300: Israel RED
thanks Roid for the codes.
i just figured out a possible way to update the 5800 with Phoenix.
Phoenix is actually does something similar to what NSS is doing but by "forcing" the software to the phone.
i'm just learning the procedure now and don't know if it will work.
you can check this link:
http://www.imserba.com/forum//forum/thread/114405/
good luck & "layla shaket"
I need the code for Asia country so i can use Chinese can anyone help me tq
These are the languages on mine from Hong Kong, can't read em to know exactly what they are though. I'm guessing Mandarin and Cantonese?
0575408 is the code.
Hope it helps.
wabcdw wrote:thanks Roid for the codes.
yea i already have latest phoenix already patched with the 5800 latest firmware.
..but.. i dont want to do the installation on my 10" laptop and my desktop currently with usb1 so i need to get a usb2 pci card first.
also i dont want to find out my phone dead 😊 even though i can go to a store and then pay 100 nis or so.
will see. actually i dont have 5800 yet. still with my n95.
Hey Guys,
Can anyone tell me the Scandinavian (Danish language) country code
for the nokia 5800 Tube? it would mean a lot to me.
Thanks !
Joe
joecrack wrote:Hey Guys,
Thanks !
Joe
0559110: Scandinavia RED
0559375: Scandinavia BLUE
Enjoy
