DreamSpring have released DreamScribe for the Series 60 platform. It is desingned as an enhancement for the PIM functions of the phone allowing quicking adding and editing of PIM items.
Author Info:
DreamSpring today released DreamScribe, its first smartphone product for Nokia 7650 and other Series 60 smartphone users. DreamScribe is designed for those who frequently need to access their Calendar and create activities. DreamScribe's innovative joystick-based navigation and activity type lists minimise text entry and the number of keystrokes. It significantly shortens the time required to create and modify entries in Calendar, To-dos and Contacts.
DreamScribe's integration of the Contacts database with Calendar makes it the ideal entry point for the standard built-in applications including Calendar, To-do and Contacts. Users no longer need to open multiple applications to get the information they need to create activities and to-dos or schedule meetings and events with one or more contacts. DreamScribe speeds up the process by making the information available in one location. To save users time and hassle, DreamScribe automatically saves the created or edited information to the relevant applications.
Details on DreamScribe's features can be found at http:// www.dreamspring.com/products/dreamscribe/index.html. A trial version is available at http://www.dreamspring.com/products/dreamscribe/download/ trial.html for users to try before purchase.
