help needed to connect wireless GPS
5 replies · 4,016 views · Started 27 December 2008
hi,
new this forum.
great work by mods and all the members .
my problem is i need connect wireless gps to i8150 via BLUETOOTH . but it asks to enter code which my wireless gps reciever cannot (obviously no number pad sort of)
Please help
but it does need a matching /similar 0000 or 1234 whatever it is need to be entered by the GPS reciever , right? which i cannot do, because...i cannot do it from the reciever
There is no need to enter it on the Bluetooth GPS (as you can't) it will already had the code set, you only enter the code on your phone when pairing.
So as srw985 says just try the standard codes and see if they work.
Though as the phone has a built in GPS why do you want an external one?
thank you guys , will try this.:icon14:
wanted to see if this is a more efficient way
