a transparent active homescreen or mixture of active and basic homescreen features ?
2 replies · 5,848 views · Started 28 December 2008
hi.i was wondering if there is anyway to make the active homescreen icons and notifications to be transparent? maybe there is a theme which allows for this or something.thanks
i was also wondering if you can use the active screen without the application shortcuts and still have the 5 shortcuts on the directional pad
reprovo wrote:hi.i was wondering if there is anyway to make the active homescreen icons and notifications to be transparent? maybe there is a theme which allows for this or something.thanks
Go to -
Tools/Settings/General/Personalisation/Homescreen
Click on homescreen it will change from Active to Basic, homescreen icons etc will be gone.
Return to Tools/Settings/General/Personalisation/Homescreen to set the 5 shortcuts on the directional pad
the thing is i want to use some other functions of the active homescreen together with the 5 on the directional pad.for example the new message notification where you can read the message on the homescreen.doesnt seem to be possible though.thanks for trying to help though.
