Can you play MMF files (like the ones used on samsung) on the P800 since there both poly-tones?
Also where can i find ring tones for new songs?
No i dont think you can use the polyphonic ring tones of your samsung on the P800. You can download lots of wav files from the internet. Just try using a search engine for wav files. They are all over the web 😊
If you use PMPlayer2 to convert MMF to MID you can then use them. The sound quality of the Samsung SGH-T100 is MUCH better than the p800 (because of the Yamaha sound chip i suppose) though and the volume is higher !!! 😞
Also the T100 has 65000 colours display vs the 4096 of the p800 and is much brighter.
Apart from these 2 things of course the p800 is a better toy.
