Aplication Deamons
1 replies · 1,641 views · Started 21 February 2003
I've recently upgrade my Active Desktop from 1.51 (EN) to 1.70 (EN) and I've found out that since the instalation eProfiles does not work properly. It no longer works. I've had to reintall it to make it work again.
My point is,�is there any way to know what is going on during the phones power up? I've Memory monitor wich displays all process and threads running but I can't control wich load or not on booting.
�Is there anything "ALA" autoexec.bat?
(I know there's a sistem.init but it doesn't seem to be what I'm looking for).
DMO
it's easy, you can install AppMan:
http://www.symbianware.com/product.php?id=appman60&lang=en
then go to Processes tab,
select Options\Settings\Exclude ROM processes
now you can see all daemons started by 3rd party applications here.
So you can learn easily which apps start anything on system boot, etc.
