SMS Problem. Pls help me!!
1 replies · 2,599 views · Started 22 February 2003
i've just upgraded my software to:
Phone:
CXC162002 R1D
Bluetooth:
CXC12529 R2C
Organiser:
CXC162001 R1G05
CDA:
CDA162001/3 R2A04
hoping to solve some probs. But my SMS sending is still having problems.
Alot of times when i create or reply to an sms, an "Information" screen will pop out saying "Not Enough Memory" and a "Continue" button. I'm unable to send it eventhough i re-create and keep clicking on the "SEND" button. And the msg in the Draft folder is EMPTY!!! With just and envelope icon with no contact and msg (which suppose to have what i have typed earlier) in it. Tried restart the phone, check SMS settings all ok... and its periodical... sometimes it happens sometimes not... can someone pls help me... thanks
Try checking with your service provider for the correct settings. If indeed sometimes your fone works and sometimes it wont, the problem might be with the hardware, coz its either it would or wouldnt work. Try having your fone replaced instead
