I have loss of 1 mbs
I couldnt find out where it can be. do you have an idea??
1 mb lost
how do you remove programs from your phone ? the correct way ? or do you delete them using a file manager ?
Have you checked the pockets of your other pants?
Try to remember where you put it last...
Have you looked under your bed? That's where mine always hides.
Maybe you can give us a bit more information to go on.. Like how you discovered the memory was lost in the first place..
I remove them from the manager in the tools. I saw the 1mb mem lost also in the manager
do you have a extra language on your phone or a block for the BT?
i have and it takes 1.2Mb and i cant uninstall it or use *#7370#
I dont know whether another lang was installed. do you mean hat you cannot remove it via hard reset or you cannot hard reset your phone?
Bring your phone down to your nearest nokia care center asap.
pffff 😞
