Viewja (View Japanese for 9210)
3 replies · 2,947 views · Started 05 October 2001
Hi! I'd like to ask you a question about a problem I have when copying "viewja" and "viewja_org" onto D
The PC Suite program, displays an error message that says "PC Suite was unable to convert because an unexpected error has ocurred". I've tried to download the zip file several times and copied it again, but always fails in the sames files.
Has anybody installed it succesfully?
Any sugestion about what I should do?
Thank you very much.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Try to move the file using the mouse and the right button. After drag'n'drop choose only "copy" and not "copy and convert".
Other idea is Use a mmc-reader to put the files on the mmc.
geoHartmut
Thanks geohartmut for the help User posted image, I hadn't thought of that possibility. I copied the files without converting them and it worked.
Now another problem User posted image I have with the same program how do I install the OPL Runtime (viewja_org)? Because, copying it does not seem enough to make it work...
Regards.
