OK, this happenned a couple of hours after i had hard reseted my phone, it was in my jacket which i was picking up to wear, I noticed it was shaking. I reached for my 7650 and found out that it had been vibrating non stop for 27 minutes when someone had miss called me, and it did not stop until i turned it off then back on, after that everything went back to normal... :-? 😮
Oh i'm still on v3.12 btw...(I know i will try to upgrade soon! :P )
So, any ideas?!!
Jamps
Sounds like just one of those things than happens from time to time with the 7650.
Mine has had several similar crashes, frozen apps and backlight permanently on.
These are probably due to some rogue app installed or running.
Not much you can do.
Bob
i once got my phone covered in snow while taking a picture of a snowball fight (somebody thought id would be funny to throw a snowball at me while i had the phone in my hand!!) anyway i got home and my nokia wouldnt stop vibrating lightly, so i took the battery off and left the nokia on a SMALL electric heater to dry out, 20 mins later i put the battery in and it worked fine.
p.s yes i'm 24 and still have snowball fights lol
Well, Im over 30 and still enjoy a good snowball fight 😃
