Hi
I'm about to switch over to the iPhone from having a Nokia N95.
Please could anyone recommend the best method of importing my contacts. I have them backed up on my PC, but just as a Nokia back-up file (.nbu) - I'm not sure if it's best to do it straight from the phone.
Also, some of my contacts have their pics attached- can I still have these intact?
Exporting contacts from N95
You can on the N95 export all the contacts to the memory card as .vcf files with the Contacts app:
Options -> Mark/Unmark -> Mark all
Options -> Copy -> To memory card
You'll find the .vcf files on the memory card under \Other\Contacts
You can also get the .vcf files from Nokia PC Suite via the Contacts functionality there.
or just sync your phone to zyb.com (or some other sync provider - but I like zyb) and install zyb to your iphone and sync it back afterwards
D
