PCSuite notification E51
1 replies · 6,037 views · Started 09 January 2009
I have a nokia E51 and PCSuite. I have seen you can get a notification pop-pup on your PC if someone call you but this don't work on my PC.
I have installed the latest PC Suite 7.1.18.0.
When i go to settings -> settings -> general
There i have selected all the options. When ik click on Check the notifications supported by this device i get 3 red STOP-sign which mean those notification are not supported by this device...
Is this normal? I think the E51 should support this feature...
Anyone experience with this?
Thanks in advance to help em on this.
Once you connect your phone with Nokia PC suite 7.1.18.0, In File Web Settings Help, Select Settings, In Settings, again look for an option called Settings,in this check for General, Notification Options, there you will have options for new call, sms and battery settings. Now you can check if your connected device supports these features using Bluetooth and Cable as well. If it is supported, you can click the options you want(say if you want a notification wheneve a new sms is received, click for notifications for incoming messages in the windows notification area). I think by default these options are not selected becuase selecting these options will increase energy consumption of your battery. To conclude, if your connected phone supports these feature and if you want to get notifications whenever new call or sms comes, then you can check the appropriate features on this settings.
Please have a note : :icon4: Not all the functions supported by one phone will not applicable with the other phone similarly if cable supports this function it not applicable it will work with bluetooth also and vice versa. Its purely phone and connection dependent feature.
Please do check these boxes only if you are really in need of this feature as it consumes more battery which will resulut in more energy. Save Earth 😊 Dont use if you dont want this feature. :icon14:
