N95/N95 8gb screen
2 replies · 1,996 views · Started 09 January 2009
do you know if its possible to transplant a N95 8GB srceen to a N95 as i have both as stupidly i paid 100 squid for the 8GB from a guy in the pub and found you its locked/blocked and i wanna know if i can strip my 95 and put 8GB bits on it if any one could help that would be great.
thank you all. =0)
Lee.
would be extremely hard as the dimensions are different between the two with the 8GB being larger..
bchliu wrote:would be extremely hard as the dimensions are different between the two with the 8GB being larger..
thats the thing i've looked an will fit bit i dunno if the workings are the same or not..??
