Help. I am getting an error ECFMSERVE.exe. I don�t know what it is but it prevents me from copying files from PC to Nokia 9210. Can anyone help
PC suite Error. Swaping Files ECFMSERV.exe
You should manually edit windows registry. Start RegEdit.
And delete the category with all included items
Nokia\NokiaConnect6\EpocDevices\(your device)\FileManager
I do not now how to start regedit. So I typed in nokia and connect 6 and manually deleted all these files. I the reinstalled PC Suite and still no Luck. I tried using another computer and it was fine to copy files. I think its a problem with windows.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
NokiaNokiaConnect6EpocDevices(your device)FileManager
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Start Button - Run and type Regedit.
It won't help. You should "help" it to unistall.
No. This "smart" NokiaConnect thinks that it knows what I want to do better than me!!! I'm seek and tide of such programs.
Done this and still no luck
Done what? Starting Regedit or deleting
"Nokia\NokiaConnect6\EpocDevices\(your device)\FileManager" - This is registry keys, not files or folders!
It has to help! Anyway, try to
1. uninstall NokiaConnect
2. Remove all registry keys beyong Nokia category.
3. install NokiaConnect
4. Restart machine.
Sorry Zeus. I tried deleting "Nokia\NokiaConnect6\EpocDevices\(your device)\FileManager"
again and it worked. Thanks a lot
